BarelyHoldenOnTogether
- Sep 8, 2019
- 14
- 4
- 3
- Location
- Melbourne
- VU SS Series II Manual
Hi crew
Recently bought a VU SS that had nasty as brake fluid in it.
I only driven it a few 100km before I did a service including the brake fluid change.
Now I did the change the way I’ve done the in the past - which is with a 1 man brake bleeder. I only pump the pedal around 8-10 times before I check the reservoir.
I don’t believe air got in the lines as it was quite slow to drain out fluid and I kept checking the reservoir however I did suck out a bunch of fluid to clean out the reservoir surround so I wonder if potentially air got into the lines.
However after the change I found that the brake feels soft - almost spongey. I feel like I have to push down about 1/3rd of the way to get bite. It does bite eventually but it needs a bit of travel. The pedal is almost springy.
Is soft feel on the VX/VUs normal?
I’ve done a change about 4 times to try and firm up the pedal. The back brakes drain easy, the big 2 pots at the front take ages.
When I do the change, the brake pedal is firm. Once I turn the car on, it goes soft. I can feel it drop as soon as the car starts.
Is that normal?
I’ve got a fg xr6 as my daily and the brakes on that are firm whether the car is on or
Off.
Or have a I got air in the abs module? Would there be any warning lights if this is so?
From what I read if I got air into the abs unit - I have to take it to a mechanic or Holden with Tech2 or equivalent software to run the unit?
Appreciate some help here
Thanks!
Is that normal?
Off.
Thanks!
