Cuzzy69
- Aug 6, 2017
- 52
- 10
- 8
- Age
- 48
- Location
- Vic
- Vs wagon exe v6 l67 vx
hi guys i bought a 9inch screen off ebay full android for 175 bucks. has a single din back and fits great. it need to be screwed to the plastic insert from behind then fitted. you will need to cut plastic out of the way from the car insert but easy with a dremel. if you buy one its very self explanatory. you will need a few small washers and tiny screws for this which i took from and old head unit internals. works awsum with my amps and easy to use. i put custom software on it car launcher and power amp pro. also used aldl droid for engine info. fits flush and i can still use the heather controls. you can get a 10 inch but you will have trouble using the fan slider
