(SOLVED) ABS ESP plus other error codes
Jharv588
Rockhampton
Ve Commodore
Had a similar issue - shop fixed it by replacing the rear ABS loom - apparently a known issue.
Should probably have a good look at those wires with replacing the sensor. They looked fine last time though from the wheels.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Give the harnesses a shake, see if you can reproduce the fault.
Jharv588
Rockhampton
Ve Commodore
Ok, so problem solved. $20 for a pair of (rear) abs sensors and a wiggle of the harness for good measure and the errors have disappeared. So, for anyone out there getting those initial codes saying there's an issue with the front speed sensors. Try a cheap pair of rears first. Brand was Matcher if that makes a difference.
VS_Pete
Donating Member
Thanks for the heads up mate
