Leo94
- Feb 26, 2014
- 6
- 0
- 0
- Location
- Brisbane
- VZ Executive
Hey,
So a little back story first, purchased a 04 vz executive v6 second hand with 165ks unregistered. Before I registered it I decided to give to change the engine oil/filter and flush out the coolant and replace with that red nulon coolant that conforms to gm specs and mixed at a 50/50 ratio. Bled the air out as per fsm excerpt posted on here for changing coolant. Now after most drives you can smell the coolant burning, it leaks from the water inlet gasket which is common but also from this spot above the engine in the photos below and leaks onto the exhaust heat shields and also transmission.
Click on the photos for the larger version, for the rest of the photos you can see them here.
