sundaydriver
- Jan 9, 2017
- 122
- 6
- 18
- Age
- 44
- Location
- Queensland
- VH 202 Blue 3.3 Vactioner
Happy 'Staya Day!
So was replacing some vacuum hoses and managed to snap both barbs and the thread off the Early Fuel Evap (EVE) Thermal Vacuum Switch (TVS) - or TVV (Valve). Yay!
Come to find, they are not an easy part to source.
Found a few similar looking parts online, from the US, but don't know enough about them to know if they'd do the job - plus they don't give you the thread measurements, so not sure they'd fit! Here's a few: One - Two - Three - Four - Five (I figure I could just blank one port on the triple trees... Number one looks most like the original - it's the only one with that little square port under the barbs - not sure what it's for/does?)
Barring that. Would it run just as well in I blanked off the EVE and/or EGR (Exhaust Gas Recirculation) ports completely - like this bloke did - with a couple brass plus?
I imagine getting rid of EGR is unnecessary if unavoidable - save the planet - but will it work better if both EVE/EGR are on, or have no effect if EFE is off and EGR is on?... or both are off?
Whats the effect on fuel efficiency and emissions?
From what I can tell, based on the attached vacuum diagram from @vkberlina web page (I can't seem to link directly to it), It would just be a case of blanking the port on the block and capping the exhaust heat valve actuator (no idea how it works?), and just cap it's sport on the manifold triple tree (looking at the yellow hoses on the diagram.)
And for the EGR (blue hoses), it's be similar process - blank the block port, the carby port/barb, and the EGR valve on the right of the carby (no idea how this works either...)
Thanks for any help team!
