Some cold air intake help please!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vs v6, Apr 22, 2011.
  1. vs v6
    vs v6 New Member
    australia
    vs
    Hey guys
    I got a VS V6 Berlina
    The cold air intake box is a normal stock one.
    but inside it is a flat filter Im not sure if it's k&n or some cheapy one?
    anyway is that better then the round filters?
    thanks
  2. darcycammo
    darcycammo Member
    Cockatoo Vic
    Did have VS Berlina now have VT Berlina
  3. vs v6
    vs v6 New Member
    australia
    vs
    Im actually looking for performance not fuel economy
    but thanks anyway
  4. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    id be starting elsewhere if you want performance, what else have you done first?
  5. soop
    soop Banned
    Smithton, Tasmania.
    2003 SS Commodore Series II
    You've got the wrong motor then.
  6. vs v6
    vs v6 New Member
    australia
    vs
    It's stock 6 apart from 2 and a half inch exhaust
    but im looking for better throttle response
    so is the flat filter better then the pod?
  7. soop
    soop Banned
    Smithton, Tasmania.
    Yes, yes it is mate.
    Stick a cam in it and do some stronger valve springs. Get it tuned and you'll love it.
  8. vs v6
    vs v6 New Member
    australia
    vs
    Was that sarcasm or?
    lol
  9. soop
    soop Banned
    Smithton, Tasmania.
    No. I am actually being serious.
    Use a bigger cam.
  10. The1
    QLD
    VS V6 Berlina Auto
    grab the above with a tune or if dont wanna spend much grab a 69mm Throttle Body and a tune and that will help your throttle response then just cut half the bottom out of the airbox.
  11. vs v6
    vs v6 New Member
    australia
    vs
    Bigger cam
    K&n filter with 2 holes on the bottom
    stronger valve strings
    that should be good for a little better performance?
  12. soop
    soop Banned
    Smithton, Tasmania.
    Yep, you got it.
    You might want different length push rods. But I'm not sure.
    Don't bother with the K&N just use a $2 ryco.
  13. vs v6
    vs v6 New Member
    australia
    vs
    Half of the air box?
    i have just cut like a 30cm circle lol
    and THROTTLE BODY 69mm SUIT HOLDEN V6 VS / VT | eBay
    is that alright? pretty cheap if it gives you like 10 extra kw
  14. vs v6
    vs v6 New Member
    australia
    vs
    Alright
    thanks for the help mate
    Step by step so im going to start by cams for now
  15. soop
    soop Banned
    Smithton, Tasmania.
    It wont give you 10kw. Thats a load of BS. I would be supised if you even notice a difference.
    30cm circle will be sweet. Just leave it at that.
  16. vs v6
    vs v6 New Member
    australia
    vs
    alright then
    just need alot $$ now
  17. soop
    soop Banned
    Smithton, Tasmania.
    Oh, you'll need lifters as well.
    When you do a cam do: Cam, Lifters, push rods and valve springs.
  18. The1
    QLD
    VS V6 Berlina Auto
    on a V8 prob would with a tune. Put one on with a cam in and a tune and you'l prob get an extra 4-5kw at a guess on v6 throttle response with either will be better gets rid of the crappy v6 lag. Comes down to $$$ with performance.
  19. darcycammo
    darcycammo Member
    Cockatoo Vic
    just put a V8 motor in it
