Some questions I just cant find answers for...
Fortiori
South Australia
VX Executive
Ok so I've spent a few hours looking through the stickys and while they have helped greatly there is still a few things I don't understand...
Background: I have a VX Exec (2000 model) with a Pioneer DEH-P5150UB which has seperate RCA out for Front, Rear and Subwoofer.
I am planning/considering putting in a Kenwood kac-m845 (4 channel 720w) amp which has the following outputs:
• 60W x 4 at 4ohms (20-20kHz 1.0% THD)
• 90W x 4 at 2ohms (1kHz 1.0% THD)
• 180W x2 at Bridged 4ohms (1kHz 1.0%THD)
(FYI: Using a Kenwood 3012box 12'' Sub)
To me that looks like 4 60w speakers, 4 90w speakers and 2 sub woofers but I'm guessing that is wrong?
Also, as I am doing the install myself, I have a couple noob questions about installation. Is there anything wrong with mounting the amp under the parcel shelf? Also, when fitting splits where is the best place to mount all the components?
Thanks heaps for any help
Fun_Bucket
35
Cairns White Rock
Cruze II sri
Your getting yourself confused with the impedance levels (ohms) and the amount of outputs the amplifier has.
The amp has 2 different power ratings for each of it's 4 channels, as it is stable at 2 different impedance levels, both 4 and 2 ohm.
The 2 ohm rating is pretty much irrelevant as the majority of aftermarket speakers have a 4 ohm impedance anyway.
What is the amp supposed to be running? I ask because you mentioned a 12'' sub, nothing about speakers, and then a 4 ch amp.
Exactly what components are you reffering to with regards to installation? A bit more detail is requited until we can ask your questions in full.
Fortiori
South Australia
VX Executive
Thanks for al your replies.
At the moment I have the pioneer h/u with Front and rear door speakers that came with the h/u (cheap 25w). I want to replace the front speakers with 6'' splits (thats what i meant by components) and have these and the sub running off the amp while keeping the rear speakers running from the h/u.
acarmody
Donati..Whoa Green
VX Berlina
The only change I would make is just leave the rear door speakers unplugged. If they are crap than don't mess up the better quality of the front splits by having the rears foul up the air.
Other than that, make sure the splits are capable of handling about 60wrms at 4-ohms, to utilise the amp, and the sub about 180wrms, and make sure it is a SVC (single voice coil) 4-ohm sub, or a DVC (dual voice coil) 2-ohm sub. Though I'm guessing most of the lower end subs will be 4-ohm SVC subs.
Fortiori
South Australia
VX Executive
acarmody,
The splits I have in mind have a 120 RMS at 4 ohms and the sub is a 400 RMS SVC at 4 ohms although it does say something about a '2- layer voice cone'.
My real question right now is how much can I actually run off this amp? Just the front splits and a sub? Or do I make provision for some rear splits / 6x9s?
acarmody
Donati..Whoa Green
VX Berlina
Just the fronts and the sub, and even there you are seriously underpowering them all.
You might want to seriously consider getting some bigger amps.
And don't worry about the '2-layer voice cone' thats just marketing.
Fun_Bucket
35
Cairns White Rock
Cruze II sri
Have you actually bought the sub yet or just picked it out? SVC subs can make it difficult when trying to find an amp on a tight budget that offers enough power to really drive a 400 watt rms sub.
Their are plenty of entry level subs that will be rated continously around the 400 rms mark, but as far as amps go, you won't find a entry level amp that will produce those kind of figures at 4 ohm which is what most SVC subs are. Opting to spend just a little more getting a DVC sub can save you money when purchasing an amp.
Also as mentioned, that amp is WAY to small for the task, limiting the performance of both your front speakers and your sub.
Fortiori
South Australia
VX Executive
Thanks heaps for your help so far... EDIT: Also the penny has finally dropped on why I was reading the specs of the amp wrong... Thanks
The only thing I've actually bought is the H/U at this stage and everything else is planning as I knew I'd screw up somewhere in the figures.
What would you recommend? Obviously I'd like to run the front splits somewhere a lot closer to what they were designed for... And I dont mind spending a little more for a DVC sub. Can you recommend a amp/sub combo to suit?
Fortiori
South Australia
VX Executive
Ok I've done some hunting and come up with the Fusion CA-AM41200 amp and Pioneer 308D4SB 12" Subwoofers In Box. The amp's Specs are: 110W RMS x 4 @ 4Ω 1%THD+N; 150W RMS x 4 @ 2Ω 1% THD+N; 300W RMS x 2 @ 4Ω Bridged 1% THD+N and the sub is 400w RMS with 2 ohm DVC.
What do you think?
... I'm assuming I can bridge 2 channels to run 300W RMS to the sub and leave 2 channels to run the front speakers at 110W RMS? And how does it work if the amp produces 300W RMS @ 4ohm, does it then produce more at 2ohm?
