hi, was wondering if any1 knew of a spray that would help the sticker badges (ecotec v6, commodore), and the sticky **** it leaves behind come off easy without damaging the paint job etc. any1 no wot its called and where its from? thanks
just pour some hot water out of a kettle over it and peel it off, thats how i got my badges off.. could even use a hair dryer to soften the glue up
I swear by k+h wax and grease remover + hot water and a rag to get the glue/sticky **** off. It is a solvent base cleaning fluid and will not damage your paint what so ever. To get the badges off, I recommend using some fishing wire.
use some fishing line to cut the glue off then use some hot water or eucalyptus oil (make sure u wash it off soon after) that worked for me, it didnt leave any residue at all...
once the badge is off just chuck a bit of polish on it and the glue should come off. just make sure u put a little bit of elbow grease into it... i used meguairs paint cleaner but polish should do the same job... cheers ryan
my fishing wire and hot water didnt work for me when i took mine off my vl. a few paint chips stuck to it and i was so careful. and turps got the sticky stuff off really easy, then gave it a wash and perfect.
