ok so i have a problem with my vents the air will only come out at the demist, and when u turn the dial there is nothing. now i have looked for the control module which controls the vent selection which is suppose to be situated underneath the brake reservoir, and here is where the problem is, there is absolutely nothing there but bare body, any idea where it could have been moved to or where else it could be located? its in a vt ss, series 1, 5.0L thanks heaps chris
Here is a thread that was from today as well that might help, so maybe a search would have found it. There is nothing under the brake reservoir to do with the air conditioning. The vent selector switch (dial) controls the vents in standard A/C (not climate control) If you have climate control then there is a vacuum solenoid pack which is located on the lower rear of blower motor housing. http://forums.justcommodores.com.au...1997-2002/180640-aircon-will-only-demist.html
