someone please help
demingus
vk calais
i'm installing a tacho and have connected everything rightbut cant find the pulse wire i've checked every wire behing the dash but nothing. the standered tacho dident work so the fella i bought it off must have done something. i'v tryed everything people have told me to do and nothing is there any possible way to connect the tacho pulse wire directly to the coil its a vr coil pack if yes witch wire do i connect it to please help driving me insain. cheers
SMIT
Donating Member
35
Mornington Peninsula, Victoria
VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
yes its possible to connect it to the coil pack, but from memory it ise'nt as accurate. also does a VK evan have a tacho pulse signal?
demingus
vk calais
well its a vn engin with a vr coil pack and i've tryed pritty much everything but dosent work no wires in the dash work for the pulse so i dont know what else to do
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
should be a brown wire at the dfi module thats rpm pulses.
demingus
vk calais
where is the dfi module located and is there only one brown wire?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
the dfi is under the coils with a wide plug on it there is a tan and black wire in there too.
