Something Screeeeeching!
Robbo VS3
In The Sticks NSW
VE SSV PHANTOM
There is a god awful screeching/squeeling sound coming from my VS. I assumed it was the drive belts, but i had them replaced just last week. The screeching continues and i don't know what it could be, its hard to tell where its coming from, it sort of sounds like it is coming from the engine bay, but it could be underneath. It only seems to do it when im moving. Its loud and people are looking at me funny when i drive down the street. Please help! Any ideas?
Cheers guys.
Pie-VK
That guy.
30
Wollongong, NSW
Series I VY SS Ute 5.7/M6
Brakes maybe?
Other than that i'd check your belts and see if they're tensioned properly like Nemisis said.
Robbo VS3
In The Sticks NSW
VE SSV PHANTOM
The noise is not worse under load, i don't carry much weight. I did'nt put the belts on, the auto place did it when i was getting it serviced, but the noise was there before the new belts were put on.
I said to the guy, there is this loud screeching noise, and he said yeah its probably just worn belts, anyway he chucked the new ones on and the noise is still there and now its actually getting worse.
I don't think its breaks, i don't touch the break pedal at all when its happening. I had new break calipers and pads put in just a few months back. I tell you this , i get the shits with these bloody old vehicles, always problems and costing money. Have spent nearly $2500 in the last 6 months! I would rather try and fix this prob myself rather than pay someone $300 to do it for me, but i just don't know what it is.
nemesis_adrasteia
better to reign in hell
longford, victoria
VR commodore HSV(without all the gay ****)
is it a 6 or an 8?
does the noise change with clutch operation?
you had new calipers and pads but not new rotors?
vl_nick
VL Wagon, VF Redline
my money is on a worn out idler pulley, remove the belts and spin each pulley to check for worn bearings
HoldenManDan
Built, not bought...
Penrith, NSW
VS Exec SII 4.2L L67 T56 :D
Mate you could try looking at the pulleys individually? Take the belt off and give each pulley a spin to see if the bearings in them are stuffed. Stuffed pulleys might still spin fine, but can also make a noise. Take the pulleys off and shake them too, if it sounds like the bearings are rattling around then theyre buggered.
Just a thought...
Robbo VS3
In The Sticks NSW
VE SSV PHANTOM
Good suggestions fella's. Nemesis it is a 6, it does'nt change with clutch operation. Rotors? Possibly. Hey Nick and Dan, worn bearings is highly possible. I'll look into it. Thanks men.
nemesis_adrasteia
longford, victoria
ok, i think these guys are on the right track with the tensioner pulley.
may also be that your water pump bearings have let go, the aircon pulley may have seized,
check the tensioner pulley make sure it spins freely and doesnt make any bad noises, check your tensioner arm for tension, also check the belt for signs of slippage
Robbo VS3
In The Sticks NSW
VE SSV PHANTOM
Alright, i went for a drive this morning and noticed a couple of key things. The noise slows down as the vehicle slows down. And when i reach high speeds the noise stops, and after i have been driving for a while and the engine is warm it does'nt make the noise, it seems it only happens when its cold???
