Sometimes low power in window
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by umair, Oct 8, 2011.
  1. umair
    umair New Member
    saudi arabia
    Sold my car :(
    Sometimes when I try to put the window up it goes really slowly and sometimes not work. At other times it goes really fast. This is with all windows. At night when I raise the window up I can see the gauge light dim. Also when I open the lock up somtimes all lock open and sometimes 3 of them open.
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    If that is with the engine off it could be your battery is becoming weak.
  3. bogan_vk
    bogan_vk New Member
    australia
    commodore
    sometimes its the rubber bailey channel and door rubbers that make your window go up slowly.
  4. Tim Smtih
    Tim Smtih Sexy Man
    Here.
    just buy a v8 lol
    I've been advised to use a silicone spray on the runners, can take some of the strain off the window regulator.
  5. Killr6
    Killr6 tutut
    Hervey Bay QLD
    BA XR6T
    If its all 4 windows that are going slowly as said could be your battery dying.
    but also check your switch it could be faulty and check the wiring (just a few cheap things to look at)
    and change your power window relay.
    Dan.
