soot on back of car
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by 96calais, Oct 16, 2012.
  1. 96calais
    96calais New Member
    maroochydore
    96 vs calais series 1
    hi, had a good read on the forum, im chasing the latest thoughts on exhaust soot. sic of cleaning the back of my vs 97 clubsport
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Sounds like its running rich if its blowing a lot of soot out the exhaust..When were the 02 sensors and air filter replaced last?
  3. 96calais
    96calais New Member
    maroochydore
    Both have never been changed, only had the car for 5 months
  4. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    I would start here then.
    Sounds like its running rich.
    Whenever I buy a car I always replace plugs, leads, O2 sensors & filters as they are all wearable parts and unless I know the history of them I don't trust them
  5. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Just about every unleaded car will get a small amount of soot on the rear, it will be more noticeable on lighter coloured cars. If you don't think you are, wipe the bumper above the exhaust with a white rag and see how much black you pick up.
    Carbon is one of the elements created when fuel burns, carbon is black, it is only natural to expect it to accumulate on the rear of the car where the exhaust exits.
    But if it is an excessive amount, then you may have issues.
  6. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Short runs will also make this worse as the moisture that condenses inside the exhaust does not boil off and gets sprayed out the back as water droplets instead of steam. High humidity will also make it worse.
  7. yZoH
    S/E Subs, Melb
    (0.o')
    How's that cat converter going?
  8. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    can't do much about crap sticking to the back of a car, the back of a car is a low pressure zone compared to anywhere around it... if you ever see a car that is blowing smoke you'll always see oil and crap all over the back of it, anything coming out the exhaust doesn't go straight back and away, it hangs around the back of the car while it's in motion..... can't beat the law of physics unfortunately.
  9. VR38
    VR38 Well-Known Member
    VB SL/E
    Sounds like it is running rich to me.
  10. 96calais
    96calais New Member
    maroochydore
    just bought a new air filter I'll see how that goes over this week. I put stainless dump pipes on the car which has helped. Still not good enough though
  11. Maxmadmat
    Maxmadmat Member
    Rotorua, New Zealand
    VR Berlina Wagon 3.8 & VS Sedan Manual 3.8
    Obviously a diesel powered Commodore... ;-)
