Spark plug heat shield
Jrevell13
Holden vu s
Just purchased new spark plugs (ngk) and new leads(eagle) and i was wondering if I need to buy heat shields for the leads or they don't need them? Thanks
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Do you still have the factory leads with the heat shields on them ?
If you do, the heat shields should pull off the factory leads and fit onto the eagle leads.
Immortality
Staff member
Sth Auck, NZ
Yep, as above, just re-use what you have.
Jrevell13
Holden vu s
Yeah still have the factory ones although they don't seem to go on nicely but they do go on, but I will use them instead of not using any, thanks guys
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Don't loose them.
I priced them from Holden a while back and they wanted around $30 ea for them.
So I made my own, out of some chrome tubing I had.
When you've got a 5 litre, it adds up.
Jrevell13
Holden vu s
I'll make sure to hold on to them then haha thanks
BlackVXGTS
Melbourne, SE
If you have high quality leads, such as Magnecor, you won't need heat shields - on a V8 Commodore anyway, can't say for a V6. If you were installing large primaries - 1 3/4", 1 7/8" they might be useful as the boots/leads will be much closer to the exhaust.
