VEdriver59
- Feb 22, 2013
- 107
- 4
- 18
- Location
- Perth
- VE, 09 of 2008, Omega, Auto, 3.6 Litre, 6 Cylinder
My VE has done about 120,000k and using a heap of fuel so I'm looking at replacing the plugs in the hope that this will fix the issue.
One Sunday a while back I started out with a half a tank to get from Joondalup in Perth to City Beach a distance of about 50-60ks at most. I got where I was going and then started home again but realised there was near zero fuel in the tank and I very nearly run out of fuel before could get to the nearest petrol shop. Its this event that alerted me to how much fuel I am using. I'm unemployed these days so I only do short journeys around our end of town now so a tank of fuel lasts quite a while.
I've read one of the causes of excessive fuel use may be the plugs. I have cleaned the MAF but I either may not have done it right or I may have touched the wrong part because cleaning it has not made any difference to fuel consumption. I've also replaced the air cleaner filter thinking that may have something to do with it. I dunno when the plugs were replaced last as I brought the car about 4-5 years ago at an auction. It was a govt car and had 105ks on the clock. there no maintenance records that went with the car.
The more I read about changing the plugs the more involved it seems to be. I'm reading that not only should I replace the plugs but also the leads and also the Ignition Coils. Is this right?
All contributions appreciated
thanks
thanks
