Spark problems
GryWgn
LOOOK AT MY UTE
Vic, Country
forums.justcommodores.com.au
Vu S Pack ute LS1
Hey guys, recently my car is playing funny buggers, now im thinking this is going to turn out to be a major problem, but it might not be.. so this is whats going on... it does not spark on cylinder 2 and 4 i think anyhow any ideas on why it is sparking on some and not the others, it starts and all but running on few cylinders, im boggled:bang:, and its a vl not the vx as i sold it:p
VPplayer
Melbourne, bayswater
VP Exec
first check your spark plugs, then your leads and then your coils. they are the main things to get spark
detox_nath83
Another VL Driver
37
Queensland(Sunny Coast)
VL Turbo Commo
do u know for sure it is not sparking on those cylinders mentioned
does it run any different if u unplug one ?
As VnPlayer mention Spark Plug/Leads and coil.
Others could be CAS disk is diry/debris in the slots for the LED sensor not to work
Check my thread on "Step By Step guide in changing CAS" to locate Disk
GryWgn
LOOOK AT MY UTE
Vic, Country
Vu S Pack ute LS1
yes when i unplug the leads from the dizzy the motor doesnt change beats, and doesnt spark from lead to dizzy as im sure u would know, i will go buy coil and a 2nd dizzy and try them both see if i can pinpoint the malfunction
detox_nath83
Another VL Driver
37
VL Turbo Commo
hows the inside of the dizzy cup look....and rotor arm contact
any broken contacts pitted/corroded. i doubt it would be coil as it is working for others.
goodluck let us know
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
check ur timing too, i was running 5 when i first got my baby.. did that replaced the dizzy and cas and now shes fine..
detox_nath83
Another VL Driver
37
VL Turbo Commo
possible contact in indicator stalk faulty
Relays in fuse box and fuses. Fuse rail melts common problem. If it has just bypass it for temporary and wire up a new fuse/holder when u can
goodluck
