Speaker sizes for VZ ute
T
TDK14U
Guest
Hi Guys,
I just recently bought a new VZ SS Ute. I am looking at upgrading my speakers. Can someone please answer the following questions:
1) Are the Speakers splits are coaxial
2) What size are the speakers (i just want them to be directly swapped)
3) If they are splits, where are the current tweeters.
Many thanks
barbs
w-sydney
VZ Monaro CV8
i believe they are 6" splits not 6.5" - the tweeters are under the vents at each on the dash
there are no cross overs with the standard speakers by the way
cold_carve
Sth East Vic
VE2 SS 6sp Manual
Care to take a look
http://forums.justcommodores.com.au/showthread.php?t=25911
ive done an extensive writeup on replacing speakers (woofers n tweeters) for the fronts as i did first hand meself with my ute - fitted a pair of JL 6 inch splits
anywas to simply answer your questions... front doors are splits with 6" woofers - no xover just a filter capacitor on the factory tweeter,
and the tweeters are located under the vented area - article will explain in detail how to dismantle for access
see if thats any help!
T
TDK14U
Guest
Hi Guys. Thanks for the help.
So after reading the above thread, the stock speakers are 6", but 6.5" can be fitted. How much modification is needed to fit the 6.5" speakers, is it a big job? I don't want to modify the cartoo much.
Patrio7
3Y3 K4N 5P33K 1337.
Perth, Como
'96 S1 VS Exec
depends on the speaker your putting in, some pioneer ones can be screwed straight in no problems, others require cutting away the back end of the door pod
squire_j
41
www.cardomain.com
Turismo Blue 2005 VZ Storm Panelvan
garfa
SE Victoria
VY SS
if they do need any cutting it will only be minor.
