Speed Sensor Leak
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by someguy360, Mar 24, 2013.
  1. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    Hi Guys.
    Noticed I have a fair sized leak coming from the VSS on my Transmission on the VR (dropping a couple of hundred ml per night on the drive)
    Have fixed leaks from everywhere else e.g pan....tailshaft CV etc its just this one remaining.
    I assume there is a gasket or a seal behind the sensor?
    If so does anyone know the part number for these as I tried contacting repco and they claim not to carry anything on the shelf like that?
    Thanks
  2. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    The VSS has an "O" ring seal. You may have to remove the existing one and take it to a place that deals in "O" ring seals. Make sure you get a seal that is compatible with trans fluid (eg. Nitrile rubber).
  3. K-BAGZ
    K-BAGZ De Plane! De Plane!
    Far North QLD
    VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
    Good trick which will maybe help you is to flip the o-ring over and add some vaseline on the o-ring and reinstall. Worked for me numerous times doing breakdowns at my work. Worth a shot, it'll cost you nothing.
