Speed warning message
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Siggz, Jan 6, 2011.
  1. Siggz
    Siggz New Member
    VY Berlina
    Bit of a noob question but I can't figure out how to turn the warning off on my dash. The highest it goes to is 110 km! I do a lot of travelling on long open roads so you can imagine my frustration :bang:
    Any ideas?
  2. Chilly
    Chilly New Member
    Adelaide!
    VT Commy
    Use a hammer??? ;)
  3. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    Do you mean the overspeed alert? Press mode button once and the overspeed will be displayed, press up or down arrows to change it in 5kp/h increments.
  4. Siggz
    Siggz New Member
    VY Berlina
    Mine doesnt go over 110 km/h FML, is there a way to turn it off?
  5. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    Havn't heard of that before, mine goes up as high as I would wish to set it. Dunno mate.
  6. kalekale
    kalekale New Member
    Berlina
    hold the up and down button at the same time, or whatever the VY has to do to reset the trip computer. At least, that is how to do it on a VT.
    Awesome inbetweeners pic.
  7. Prizy
    Prizy New Member
    Bendigo VIC
    VE SSV 6.0
    i managed to turn mine off after fiddling around with it traveling around 80km.
    i held down the mode to set it,
    then pressed mode, then held mode,
    something along these lines, and it actuallys says "speed off" which is great :"D
    (VY II)
  8. lein
    lein Comrade Commodore
    Tropical QLD
    VC 202/4sp
    First step.. Did you check the owners manual. From memory the VY book even tells you how to reset the service due reminder, something they left out of the VZ book.
    Anyway, I believe you hold the up & down arrows when you turn the ignition on. This will give you, all your headlight timings and the o'speed setting. From memory. I'd check but I'm in the work car.
  9. wikky
    wikky ............
    Here
    VZ SSZ
    Nope, my manual has it in mine.
  10. Siggz
    Siggz New Member
    VY Berlina
    Thanks guys I will give these suggestions a crack and get back to you!
    I've only got the gregorys VT-VZ manual and its pretty limited.
    :beer chug:
  11. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    Hey siggs, have you tried the method that I posted^^ a few posts up? Because unless there is something seriously wrong with your computer you should be able to set the o'speed to any speed using this method.
  12. Braydenreid
    Braydenreid New Member
    canberra
    S/C VX Calais
    i just pushed the mode button untill it showed the over speed on the cluster screen, then held the mode button for about 4 secs and it turned off...
  13. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    mines gose up to 200kmh it has only ever went off at me once
  14. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    LOL. I had mine set at 110, but found that it pissed me off too much, so it's now set at 115, only hear it when overtaking sometimes.
  15. Kernal
    Kernal New Member
    NSW
    mine goes to 200. ive beeped there =)
  16. Jezza
    Jezza Ecotec Just Kicked In!
    South Australia
    VYII Acclaim
    mine doesnt bother me anymore since i got the "police pack" done through a tech2 i now have the digital speedo instead
  17. caaf
    caaf Member
    Melb, Vic
    VYII Equipe S/wagon V6
    Well that would be a silly thing to say on a open forum as you may find with your above quote a less than desirable out come.
  18. brokenikon
    brokenikon New Member
    Gold Coast, QLD
    2011 VE Maloo: 2008 VE SV6: 2004 VY II R8 Maloo
    I acknowledge that you do have a good point there, do be careful as to what you post on the forums, there's bound to be someone out there who'll be a complete tool.
    But, despite the fact he clearly meant that quote as a joke, same with the earlier guy, there's nothing in the quote that constitutes an offence.
  19. Siggz
    Siggz New Member
    VY Berlina
    We have a winner, thanks for all the suggestions but this one worked !
