Speedo Accurate?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by ChewieSV6, Jun 16, 2013.
  1. ChewieSV6
    ChewieSV6 Member
    Frankston Vic.
    2012 SV6
    I was wondering about the accuracy of the speedo on my new (to me) VE series II SV6.
    I have a triumph Speed Triple which I have calibrated the speedo and know it to be accurate. It seems to me that driving along the freeway so many of the other vehicles seem to be doing about 93 or 94kph but probably believe they are doing 100. I have come to the conclusion that the speedos on most modern vehicles are reading about 6-7% fast. My Speed Triple was 7% fast before I adjusted it. Has anybody here compared their speedo reading to a GPS output, or had the car on a dyno. I'm talking about vehicles with stock wheels and tyres.
  2. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    I defended a couple speeding matters in court recently, 245/40R19 is 3% slower than reading, 255/40R19 is about 1% over speed.
  3. HEXEM
    HEXEM Member
    ACT
    VE II SV6
    Yep run my Satnav all the time and will show a 5klm variation. Speedo will read 100klm and GPS says 95 or 96 (variation). I've been told that the speedo in VE can not be calibrated to correct it, something about an ADR compliant thing or similar - I'm happy to be corrected and if there is a fix please post how it is done and who can do it. I was told by one of the holden techs that they could play with the tyre sizing setup in the ECM but not sure how that works..... Our VY commodore speedo is spot on with the GPS.
  4. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Hexem not a fix per sé, but the wider tyres on the wheels above give a circumference near enough to perfect. OFC not a good a reason to change tyre spec by itself but I find the lil bit wider makes vertical side walls, is OK still, no flab.
  5. Aussie Willy
    Aussie Willy Coal Miner
    Hunter Valley
    VE SSV Redline 2012
    It is legislation, speedos are to be a few KM/h slower than actual.
    Cut and paste
    Australia has standards for speedometers similar to those of the European Union; and most car manufacturers aim to adhere to these standards. The rules say that no speedometer should read lower than the speed you’re travelling – so you should never be going faster than what the speedo reads.
    But in terms of your speedo reading higher than your actual speed, a huge margin of error is allowed. For a car, the international standards allow a speedometer to be higher by as much as 14km/h at 100km/h – which means your car is doing 86km/h when your speedo is showing 100km/h. For a motorcycle, 84km/h actual speed is allowed to read as 100km/h on the speedo.
    Source
    http://www.consumer.org.nz/news/view/speedometer-accuracy
  6. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    ^^ true dat, found in court that ignorance of circumference was not an ideal defence in itself regarding choice of replacement tyres, but useful rebuttal tactic by way of contribution to the unavoidable cumulative error of the VSS reading, its interpretation by the cruise control program, going downhill immediately after an apex, hit by LIDAR, in a two tonne automatic.
  7. Fekason
    Fekason Fekason
    Penrith NSW
    Hi,
    With the speedo's now run by computers and not a cable, there seems to be a fixed underead of 2 to 3 KPH on each of my SV6,s - MY09, MT11 and MY13 Z.
    Back in the days of my VS with a three window cluster, it was possible to enter a correction for distance and fuel flow to get the trip computer spot on. That did not change the analogue speedo reading or odometer though.
    It's a bit of a pain, but I set cruise control at +2 with my current SV6 and know that the speed is spot on.
  8. gossie
    gossie Well-Known Member
    Gold Coast.
    VE International 3.6L
    My VE reads 5K over.
    On 110K roads I set cruise at 117 and have never had a problem, touch wood. I don't like dawdling along holding up other road users as I don't like being held up by people "thinking" they are driving close to the limit.
  9. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Discussion of speeding on public roads is not allowed, so allowing for slightly greater yet unquantifiable speedo error... because technically you believed that was not speeding, right...
    In my all-too-familiar experience if you travel at 117/110kph as indicated on your speedo you will either be pursued and issued with a warning or ticket in every State, else you will receive a camera notice in the mail.
    A defence in court is entirely possible with a human police officer, and is your right, but clearly a waste of everyone's time and money on the day. Even when armed with an intricate knowledge of the law, not worth it.
    115kph is arguable, not with camera detected, and not easily with video footage accompanying LIDAR.
  10. WazzaV8
    WazzaV8 New Member
    Esperance
    VE SSV Redline
    Have you tried a measured kilometre, my VE is close enough when I use the digital display.
  11. WazzaV8
    WazzaV8 New Member
    Esperance
    VE SSV Redline
    Did you win though, I would think a magistrate would blame you if your speedo was out and blame the cops if the radar gun was out, after all it's up to you to be sure that your speedo is correct and up to the cops to make us the radar is reading correctly and operated/service per manufactures specifications.
  12. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Negative, found guilty as alleged, despite a couple of valiant efforts to blame it mainly on the speedo, Arrr!
  13. WazzaV8
    WazzaV8 New Member
    Esperance
    VE SSV Redline
    You should have tried the never fail excuse "I heard the area was a speed trap so I was trying to get out of there quickly"
  14. yxyx64
    yxyx64 New Member
    nsw
    Kia turbo + Holden badge, Chev badge in Texas
    yep, what I tried to explain that in the other thread before all the ADR speedo % experts chimed in. It is the drivers responsibility to stay at or under the speed limit. Blame Holden or ADR% or coasting down a hill or whatever all you like but you will lose in court if you exceed the speed limit - even in a 1922 Model T Ford that does NOT have a speedometer. It is the drivers responsibility. The law does not care how you keep under the limit - but keep under it you must.
    There are only two reasons people speed...............
    (count up by 1 bird bloke)
  15. ChewieSV6
    ChewieSV6 Member
    Frankston Vic.
    2012 SV6
    I spoke to a mechanic today who specializes in hotting up Commodores, mainly V8's. They have their own dyno and they usually check the speedo against the dyno's speed indicator. He said its generally 4-5%, which agrees with what Hexem said above in post #3 and Gossie in post #8
  16. Reaper
    My 2 SSV's each were doing 96 km/h when the speedo indicated 100. My E3 does 97 km/h & 100 on the speedo. The most accurate way to check is use a GPS based speedo on your smart phone or satnav. There are plenty of free android based speedo apps and I presume there are iPhone ones too.
  17. Sean880
    Sean880 Well-Known Member
    VIC / NSW
    2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
    You should be aware that in most states the fitment of replacement tyres (or tyres/wheels) is conditional on your vehicle retaining speedo accuracy. If you fit a larger tyre or a new wheel/tyre package that also results in a larger diameter tyre which is sufficiently oversize to cause the speedometer to under read the true vehicle speed, then that is your problem and it is a violation. You are either required to recalibrate the speedo to correct the under reading of the true speed or if that is not possible to fit the correct size tyre that will not result in the true vehicle speed being under read by the instrument.
    If you are caught speeding and have an inaccurate (under reading) speedo because you fitted tyres that are too over size then you have 2 FAILS :
    1. Non compliance with the tyre/wheel replacement regulations
    2. Exceeding the legal speed limits.
    Ignorance is no excuse and nor should it be.
    Given that some people will fit a slightly oversize (in diameter) tyres on their car it is not a bad idea if manufacturers are in fact calibrating speedos that under read the true vehicle speed by a small percentage (say 3-5%). Hence if I can fit a 255 35 20 tyre (686 mm diameter) instead of a 245 35 20 tyre (680 diameter) on the VE it will read approx 1% below the indicated speed compared with running on a 245 tyre because of the larger diameter. Thus, with such a tyre change, I don't have to be concerned about the true vehicle speed being above the indicated speedo figure with the bigger tyre. If GM has in fact set the speedo at about 5% under true speed on a VE (100 kph indicating when actual running speed is approx 95 kph) I would be well within the margin in this example. (Similarly some guys like to run a 285 30 20 tyre on their big (9.5 or 10 x 20 inch) rear wheels on the VEs rather than a 275 30 20. It is useful if you can do this without worrying about your speedo under reading true speed due to a slightly larger diameter tyre (285) being fitted).
  18. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Thanks for taking the time to explain that Sean.
  19. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    I have argued many times with Holden Dealers (Workshops) in regard to inaccurate speedometers. According to ADR (Australian Design Rules) manufacturers are allowed up to about 5% fast. This means at about 100 km/ph you will actually be doing about 95 km/ph One good thing is that if you stick to the indicated (speedo) speed you should never get any speeding fines. Not bad eh !! Before you all jump in (boots and all) YES Police speedometers can be adjusted for greater accuracy.
  20. yxyx64
    yxyx64 New Member
    nsw
    About all we can do so good, but
    what is the accuracy of the gps? (the civilian data system)
    Also, you must realise that the US govt controls gps data (and has been known to 'adjust' the data when it suits them. What else, as the satellites fail the US govt is not launching replacements for civilian system and fewer sats mean less accuracy.
