Speedo cuts out at 100km then pops back up.
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Bz Kn33z, May 30, 2008.
  1. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    My L2 dash shat its self the speedo didnt work everything else did but the speedo, so i got another 1 of a mate and put it in and it works but when i get up to about 90-100, the needle goes down to 0 the pops back up to 100, is there any way i can fix this? i thought it might be a voltage problem like the sticky dash or something, so i might pull it out and resolder the volt thing:p but could it be something easyer any ideas thanx
  2. greenfoam
    greenfoam New Member
    VP Executive R-spec
    A broken speedo sender fuse does that, check it
  3. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    where would that be located, i checked the speed sensor and seems to be ok.
  4. greenfoam
    VP Executive R-spec
    In the fuse box :)
  5. h0Ld3n`VN
    h0Ld3n`VN New Member
    NO CAR ATM.. -.-
    if your problem still exists, get under the car drivers side of the trans there a cylinder looking thing attached to it.. its screwed on so unscrew it, unplug it from the car and give the connections a good clean with WD40 or sumthing similar and there ur problem solved, unless ur speed sensors dieing.. and remember to screw it back on very tight mine was loose n the speedo was jumping n remember to clean it :)
    laterZ
  6. h0Ld3n`VN
    NO CAR ATM.. -.-
    oh yea and it got nothing to do with a sticky tacho etc.. try that what i posted abovee and let us know how its going
