Speedo jumping in park
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Wombles, Nov 16, 2012.
  1. Wombles
    Wombles Cars cost too much.
    95 VS Wagon. Exectutive.
    Speedo jumps up when you hit the accelarator in park.
    What would cause this?
  2. aussieakito
    Melbourne, Victoria
    Shorting wires from the Revs to the speedo could cause this?
  3. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    Check out the VSS..
  4. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    **** design, the speedo is driven from the pcm, somewhere along the lines there's some interference in the computer, vr/vs do
    it and probably more, no fault and not much you can do about it
  5. Wombles
    So it wont effect roady at all.. May just **** me a little..
  6. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    mine does the same. only if i get it above 3500 in park. might just be a bit of signal interferance or as mentioned above, vss could be faulty
  7. fatboyvk
    fatboyvk New Member
    taihape
    1995 vr commodore
    my vr does the same thing
  8. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    My VT does the same as well.
  9. Wombles
    My sedan doesnt so it.. Just the v8 wagon.. It goes up when the revs go up.. At any rev range.
  10. VPRob
    VPRob Active Member
    nowra, NSW
    VP executive sedan V6
    my advice is to cut down on Speedo's red food colouring consumption
