Split hose
94SVR
VR Commodore S
Hey people,
just goin over my engine today and discovered a split hose, that connects from the throttle body to the inlet manifold. My car has been idling rough for a while and im wondering could this be the problem?
Scooter79
44
South Coast, NSW
VSII Calais supercharged
Quite possibly. Take the hose off and give it a good wrapping of electrical or gaffa tape covering every part of the split. Replace and see of that helps.
94SVR
VR Commodore S
ok ill try that, thanks
Scooter79
44
South Coast, NSW
You tried it yet? Lets us know the outcome.
Immortality
Staff member
Sth Auck, NZ
Had a similar problem, the little elbow that conects the vacuum hose the TB had come off and i had arough idle. you should hopefully notice an improvemnt in fuel economy also:yeah:
shaggerz
Victoria Point, Brisbane
2004 VY2 SV8 A4
The proper solution would be to replace the damaged hose. Vacuum hose is like $3 per metre from super cheap in all different sizes so no excuses for not doing the job properly. Recent did the same on mine. The hose from the throttle body to the boost bypass valve was split. Slightly improved fuel economy and smoother idle.
94SVR
VR Commodore S
hey everyone,
i taped up the hose (its the PCV) temporarily till i get another one, noticied better fuel economy, idle problem still remains not as bad though, will change the fuel filter on the weekend and see how it goes then
SlyVR
Fo'sizzle....
37
VR Wags
94SVR said:
hey everyone,
http://forums.justcommodores.com.au/showthread.php?t=5313
try that mate, u might find by doing that ur idle will sit nice
SlyVR
Immortality
Staff member
Sth Auck, NZ
give the TB a good clean also, a can of carb cleaner works well but it's better to remove the TB to do that. make sure the passages for the IAC are clean
