Got it all duct taped up ATM but since I repaired it the cars idling really bad and still overheating when stopped but fine with air flow once im moving again,
I keep loosing Radiator fluid (water for now) about a litre a after a long drive then car overheats because no water, Ive just been trying to get air out the system I filled the radiator with a coke bottle funnel to get the flow higher than the engine untill it couldn't take any more then with cap off started the car with heater on the water disappeared so I refilled it and tried reving it a little and with every Rev it sucked away water I did this a few times before putting radiator cap on, just went for a decent 20 min drive and temp never went over 80 but I'm sure it will need another good amount of water tomorrow.
There is still a hissing noise from under the plenum somewhere when I rev the engine hard so I'm thinking intake manifold gasket and hoping not head gasket as oil cap looks fine but water is slightly oily,
I've got the thermostat that come with the car purchased recently that has no guts just the flow restrictor so that's why the low temp of 80, I put a new one in but car hit 120 first drive so put old one back.
