Drawnnite
Obviously Unsensible
- Sep 2, 2010
- 2,030
- 2,160
- 113
- Location
- Victoria
- 2000 Vs Ute
Quick question about the Radiator in a VS. Is it possible or likely that the bottom of the Radiator can split?
So backstory got home today, saw the dreaded green water dropping from the front. Looked in the overflow and saw it was empty (didn't open rad cap as was still just driven hot) and obviously it was dripping on the ground.
Looked all around and no leaks up top, a very minor trail on the rad fan shroud down low and pulled the underneath plastic deflector off and found a fair bit of green liquid in that metal channel under the rad.
Had an inspection cam out to get into everywhere and see as much as possible with no trace as to any Radiator damage.
Always had issues with the car, gets really hot if sitting (but is fine if driving and getting cooled). Normally sits just on or above the first major line. Fan and so on kicks in when needed.
So I guess questions are, would it likely be split right at the base and only be able to see it with rad out and under pressure?
And 2, a temporary stop leak product, any thoughts on them? In about a month car is getting parked up and engine/box is coming out, so want to save replacing the rad til then.
