StevoInSA
- Sep 29, 2020
- 10
- 7
- 3
- Age
- 54
- Location
- 5114,BLAKEVIEW SA
- VZSS Crewman LS1 Auto .VZ Ute V6 Auto. VU SS Ut
Hi Holden Lovers. Just bought Vu SS Ute 02. Drove home 150km no problem. Stopped and restarted a few times. Next day on cold start had high revs and thermo fans came on afew starts later idle ok. Drove fine then.... revs erratic, surging and stalled a few times, inbetween driving fine.... Tonight I found a split Vac hose that comes from behind the Throttle Body on the Drivers side, then I think to the Inlet Manifold at the back of the motor The hose that was split was bigger than the others between a push on hose fitting and a round metal fitting?. That appears to have a circular clamp attached to an earth wire? With plenty of oily filth in between. What I would like to know is.... Do I need to get another piece of similar hose and just put back on, or is this in fact a broken part that needs to be replaced? In which case what is it I need. I'll try & put a photo up with the split hose I removed, below the gap in the Vac hose...... Thanks ever so much for any feedback.
