spoungy brakes
kniever
40
greensy, melb
VY II Calais L67 & VN II Calais T5 5ltr
the reason it goes spongy is cos air compresses where as the brake fluid does not compress
graham7773
VT Acclaim Wagon
Have you had your brake system fluid changed? Recommended every 12 months by all car manufacturers esp Holden. Very few people get it done. Makes a marked improvement to your brakes.
wortus
As Graham said get your brakes bled. I just had my VY done, only cost me $53 and I just did our Pulsar myself, it was really dark and some air bubbles came out. I don't think it had been done in ages. I usually have the brake fluid replaced at 24 months max. If you do it yourelf suck out the old fluid and muck from the master cylinder with a syringe and refill with new fluid before you start as it helps prevent that going into the master cylinder.
MR_VX
Forced to be Fast
Townsville, Qld
VX S pac SII Raptorcharged
Ive had the car 4 years and i havent done it once, I was never sure when to replace it
was that $53 at Holden?
wortus
No at a local mechanic. I wouldn't even bother going to Holden it would have cost over $100 easy. I did our other car, a Pulsar last week myself it cost $20 for 2 bottles of brake fluid, fairly easy to do with a mate to work the pedal.
MR_VX
Forced to be Fast
Townsville, Qld
arr righto, ill give it ago on the weekend, is there a certin type of brake fluid to get or are they all the same ****?
graham7773
VT Acclaim Wagon
Any brand DOT 4 is equivalent to Holdens HN1796
wortus
I usually buy Nulon DOT4, this is what I used in the Pulsar the other day. Do you know how to do it yourself?
