The brake fluid within a caliper occupies the hottest place within the brake system. Thus it has the toughest time so should be flushed.
So my process is to open the caliper bleeder valve and attaching a drain hose going to a waste container before pushing back the piston. As such I can effectively flush much of this old caliper fluid out into the external container. Then it’s just to close the bleeder valve and remove old pads and install new pads.
Just for this reason alone (part flush of caliper fluid) you should always crack the bleed valve when changing pads.
Good practice would then be to suck out much of the fluid out of the master cylinder and fill up with new clean brake fluid before pumping your brake pedal to push the new pads against the rotor. I then follow up with bleeding the brake lines.
Doing it this way makes for an easier fluid flush during the brake pad change process. I always prefer to flush new fluid through the lines as part of my pad change.
Easy on older brake systems but correctly bleeding ABS brake fluids are more complex and manufacturers recommend specific procedures often requiring specialised tools.
But whether piston seal reversion actually occurs by not cracking the bleeder before pushing back the piston I don’t know. Opening the bleeder valve and flushing caliper fluid during pad change is a no brainer to me.
As for hose clamps, I’ve never used them on brake lines as I don’t see any need. Why put pressure on a hydraulic hose in a way opposite to its intended stressing. Using a hose clamp could conceivably cause some weakness after repeated use on the same spot thus leading to potential early hose failure? I don’t remember any manufacturers workshop manual requiring such clamp methods to avoid master cylinder back pressure? May be I need to re read my old manual
@vs-lover shops worth their weight often try and make things sound more difficult and dangerous than it actually is, may be to ensure their income stream. So I listen to what they say but often take it with a grain of salt
