Squeak belt on vs
Red
Horsham
96 VS Commodore
i have had a squeaky belt for a little while now. Checked the bearings on the pulleys with the screwdriver to my ear trick and they aren’t squeaking. I got a rag and put pressure on the belt while running to clean the belt and the squeaking stops and returns again a little while after. I have tried putting pressure on the belt with the tensioner and it still squeaks. Not sure what else to try apart from replacing the pulleys to see if that is the problem. I have noticed a little wobble in the belt on the tensioner pulley.
Cheers,
Red.
losh1971
North Tas
VE Series I SS Ute
There is a wax type block that you rub on the belt while the engine is running. Try that before anything else.
Red
Horsham
96 VS Commodore
Thanks losh1971, where can i buy that from? Would supercheap sell it?
losh1971
North Tas
VE Series I SS Ute
Possibly, Bursons would have it I'd think, as would Repco. Mech used it on my ute and it worked great. I never asked him where he bought it from unfortunately.
Red
Horsham
96 VS Commodore
You wouldn’t happen to know what it is called?
losh1971
North Tas
VE Series I SS Ute
Nope not really, it would probably have anti squeal in the name somewhere.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Quick squirt of WD 40/RP7 etc will fix it, and no, it will not make the belt slip.
Cake of soap also works.
