Squeaky brakes, quick fix?
Patti2912
P4TT1
St. Kilda
98 VT S Commodore
Hey guys, quick question,
My brakes are starting to squeak now and its getting pretty annoying.
I'm booked in at my mechanics for a service in a few weeks so i can wait until then to get them fixed, but was wondering if theres any kind of quick fix that would silent them for the mean time?
Cheers :)
FstStig
Diagnostician
Central Coast, NSW
2010 VE SV6
Try and get some anti-squeak onto the back of the break pad and the metal plate that goes onto it (Not the side the piston goes against) You could be due for new pads or rotors. Could just have a stone caught in the rotor.
baza
69
central coast, nsw
vy ss 2003 auto sedan
your brakes might have a lot of brake dust on the pads , you can wash the dust off with water . dont use compressed air , no good to breath in dust. also the pads may be glazed from use and heat . use some abrasive paper to deglaze the side of pad that contacts the disc rotors, hope this helps .
Patti2912
P4TT1
St. Kilda
98 VT S Commodore
Thanks guys, ill try these out and hopefully it gets me by until service time :)
Thanks again.
VT-565
QLD
VT
Does the squeak disappear when your foot is on the brakes?
If so, it could be the anti-rattle spring on the brake pad.
I had this problem once, took me a while to find it, but once i tracked it down, i bent the spring by hand, put the pads back in and away i went.
Just a thought
RX25SE
Real cars are steel cars.
MY07 Liberty 30R Spec B 6sp wagon
Remove the pads and apply a small amount of copper grease (Bursons sell it as anti sieze) to the leading edge of the pads. This is the small part of the metal backing plate that contacts the caliper bracket.
A bit of CRC anti squeak (again Bursons) thinly smeared in the back of the pad, where the caliper body squeezes the pad, will also help.
I install all brake pads this way, and have never had one squeal.
Maxxiz
Australian Crapital Territory
2005 VZ SV6
Bugger the products,
Pull the pads out, get a file or emery paper and take the glaze off them (the shiny coating on them), whack them back in and ask your mechanic to machine your rotors.
RX25SE
What happens when the pads wear down and glaze up again?
Products are cheaper than removing metal from the rotors.
Patti2912
P4TT1
St. Kilda
98 VT S Commodore
Just a thought
It generally squeaks during lighter braking, seems to get a little louder if i push my foot in a little more, where as if i brake a lot harder its pretty quiet. It's not one consident squeak so i feel that it may be one particular part on the rotor that squeaks everytime it goes around.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
What is wrong with a squeak anyway - it does not mean that the brakes are unroadworthy - many cars have squeaky brakes every now and then. However, the time proven method is to chamfer to leading and trailing edge of the pad...just a little. Plus a bit of a roughen up like Maxxiz says. But otherwise just live with it.
