Squeaky rear brake
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Holdenuk, Sep 20, 2012.
  1. Holdenuk
    Holdenuk New Member
    UK
    Hsv VU series 2 gen 3 5.7lt. Maloo ute
    Have a VU. The rear rear brake on drivers side has an annoying squeak. Only at a certain point on the disc im thinking. Not constant, just a squeak squeak as it rotates. Seems to come and go. Think it may be a build up of brake dust?
    Os it a common problem? How to avoid it? Maybe different compound pad??
  2. Killr6
    Killr6 tutut
    Hervey Bay QLD
    BA XR6T
    It sounds more like your rotors are getting a bit old, would be best to replace them with some new pads, there cheap to fix mate.
  3. Holdenuk
    Holdenuk New Member
    UK
    Sounds fair enough. Thanks for reply
  4. Tree cutter
    Tree cutter Tree cutter
    Mt Gambier SA
    VX Calais SuperchargedV6
    Could be a bit of gravel stuck between the pad and rotor. Some pads have a metal wear indicator that scrapes on the disc and makes a squeaking noise when the pads are worn down.
  5. goose202
    goose202 New Member
    VX Calais LS1, SY Territory Ghia
    I reckon it'll be the handbrake. Try applying the handbrake while slowly moving and see if the sound goes away. Holden sell an "anti-scrape kit" which consists of a bracket and spring to move the handbrake shoe back in to place to stop the squeak.
  6. Whitesack07
    Whitesack07 Member
    Grafton
    VX S
    I had the same problem, was my pads, they were wearing the corners away and not wearing evenly, just replaced them and all good :)
