Squealing drive belt?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Tcatfighter, Feb 13, 2011.
  1. Tcatfighter
    Tcatfighter New Member
    1995 HSV VS Clubsport Manual
    Hi everyone, I've never been the person to enter forums but I need help!
    I have a VX SS that I just brought and half way through the day the drive belt started to squeal, and now the squeal is starting when I start the car and it gets a little worse when I accelerate but after a while it get a little better, but the belt is brand new, and I have sprayed all the tensioners, and sprayed the belt with no belt slip but the squeal is still there! Ant ideas in what it could be?
  2. lufkin
    lufkin New Member
    SA - Victor Harbor
    WH Manual LS1 Statesman & VT V6 Calais
    did you change coolant by any chance, i changed my coolant and belt at same time, accidently spilt some on belt, and was pissed off to find the brand new belt was squealing so took it back to where i bought and they pointed out i had got coolant on it, turns out they were right, could it be something similar in your case? only other thing i have found to fix squealing belts is silicon spray, i have got all that no slip stuff they sell and it was useless
  3. graham7773
    graham7773 Active Member
    VT Acclaim Wagon
    water pump seized? Or one of the other pulleys?
  4. DLFHUB666
    DLFHUB666 GIT 'EERRR DONE!!!
    Nhulunbuy NT
    VX SS, PX Ford Ranger XLS Dual cab
    That normally cause's a huge cloud of smoke or at very least a burning rubber smell.
  5. ])R@G()N
    ])R@G()N New Member
    VT
    I had the same thing. Good chance its your Idler pulley\s bearing are stuffed.
    Tip: when you do it change them all, If one is stuffed the others aren't to far away from it too..
  6. graham7773
    VT Acclaim Wagon
    My water pump completley seized and the only noise we heard was the belt disintegrating. Chinese crud. Also agreeing with dragon, one pulley stoofed, the rest can't be too far behind. Better to replace all than be going back two or three times
  7. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    Cheap fix.... spay everything pulleys belts with silicon spray. available from all hardware and auto stores. and enjoy the peace.
  8. ])R@G()N
    ])R@G()N New Member
    VT
    yeah should last for at least a day before its back again or untill your bearing gives out and you get stranded out in the middle of nowhere.
  9. st3r3otyp3
    WA bruz
    VX HSV VX SS
    bearings give a rattle grinding noise which he did not specify I`ve done my tensioner/idler pulley and my water pump on my clubby and they made a unmistakable horrible noise, I use this method and it lasts for months in the summer/spring. and weeks in the winter/autumn. Though to be on the safe side take the belt off and spin the pulleys one at time they should spin effortlessly will no noise, if you don`t know how to take it off just ask.
