SRS Airbag and ABS Faults!!!
GTRwilson
sell me your VY sigs!
VZ SV6
hey everyone,
Just tonight i was mucking around installing my 4 channel amp. Mainly just running RCAs behind the headunit ect.
Anyway, after this was all done, i turned on the car to hear the stereo, and was greeted with an 'SRS Airbag Fault' and also a 'ABS Fault'
Ive tried searching but found nothing on either fault so im asking here. Will be going to Holden tomorrow arvo if i cant get any help off here before hand. Anyone have any idea what it will cost me to take it to them for a diagnose/fix?
Also, is it ok to drive with the warnings constantly on dash?(got work in the morning!)
andyman
The Only 6sp VZ Wagon
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
did you remove the seat without disconnecting the battery?,
yeah you can drive it, but if you have an accident those system may not operate, make sure all the fuses are ok
GTRwilson
VZ SV6
Holy crap yes i removed the passanger seat without disconnecting the battery!
What does this do? I didnt think that the seat was anything to do with the battery, but well there you go?
Would this have caused both faults? Just ive had the ABS fault once or twice in the past, but it went away after re starting the car and was never to be seen again, until tonight.
Where/what fuses should i check?
poweredbycng
This could actually be a sign that your battery is on it's way out. We had similar problems recently with the SV6 and it was rectified by fitting a new battery (one of the cells was completely dead).
Regards,
Dave
andyman
Orange, NSW
yes, the abs will flash up if the battery is low on charge or on its way out,
you will need a compatible scan tool or tech2 at holden to remove the srs fault
GTRwilson
VZ SV6
Anyone know of somewhere in Brisbane that could do this for me, that isnt Holden? As Holden arent open today, and im guessing Holden will be the most expensive place i could possibly take it.
Exidor
I come in peace.
Earth. For now....
Used Martian spacecraft
Buy yourself an OBD2 scantool.
They aren't that expensive.
You can clear any faults yourself.
poweredbycng
Like I said, if you're getting ABS fault warnings, get your battery checked/changed. More than likely the other fault(s) will clear as well.
Regards,
Dave
Lumps of cheese
welcome to the machine
44
Warrnambool
83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
Scan gauge ftw!
Money well spent plus you have it in case it happens again.
GTRwilson
VZ SV6
i got done for speeding today, 4 points. all while on a 1 point good behavior :(
Considering selling the old girl, so no need for my own scan tool anymore.....
