SS auto trans problem
fr34kd
central coast
VE SS
I have a problem with my auto trans shifting when giving it a good poke..... it seems like it gets stuck between gears and free revs and nearly puts me through the windscreen. It has happened twice now and was wondering whether anyone has come accross the same problem?
bennypage
VE S2 SS Sportwagon
Are you talking about down shift in active select?
fr34kd
central coast
VE SS
in all modes...... it doesnt change gear it over revs. once u take ur foot off the accelerator its fine... but it happens anywhere mainly starting from a stopped position and when u really put ur foot down
bennypage
VE S2 SS Sportwagon
Series II?
bladerunner
"needs a bit'a nitrous"
brisbane nth
VE SS UTE & a 71' deltek rockhopper
sounds like it could be a line pressure problem, one of the shift solinoids might have **** itself or about to,i'd be getting it looked at asap. if you get it serviced get them to put about half litre more fluid than the full amount in as well.it will help the line pressure a bit more and its a method used by many tuning shops.
footy
VE SSV SE 2010
it used to happen randomly in mine and my tuner said to put another 1l of transmission oil in. seems to have fixed the problem.
fr34kd
central coast
VE SS
got the problem fixed had a stage 1 VCM tune done and had something called active learning or something turned off and problem is solved......
bennypage
VE S2 SS Sportwagon
Eggcellent :)
