hi all, has anyone fitted the SV6/SS/SSV/G8 diffuser to a series 2 omega? i've searched high and low, and haven't found anything. i have found one or two bad pics of the above style fitted to a Series 1, but they change the bumper slightly between the 2 series i've discovered. i'm going to assume i will end up with 2 sets of reflectors? i can potentionally remove/fill in the ones on the diffuser, but i'm wanting to make sure it fits in fine (beside trimming some tabs, etc) and doesn't look bad before i pull the trigger on a new diffuser.
I'm pretty sure the rear bar didn't change between series 1 and 2 since most people converting their s1 omega to a dual exhaust get a s2 omega diffuser, and it's a perfect fit. A ss or g8 diffuser do require some work to fit on an s1 anyway so I'm assuming the same applies for an s2
perhaps it's a wagon thing then, my Series 2 wagon is identical to the calais above, whereas the Omega sedan has the reflectors in the diffuser panel. my question therefore should be, has anyone fitted the SS/G8 diffuser to a wagon?
