SS turns over but wont fire
metalskin
get sum
47
perth
73 HQ,VR & supercharged VS SS`s series 11
she just doesnt wanna fire, i have power to the coil, all leads are on, fuel pump is working. after turning over i noticed the motor will run backwards for a sec, is this a sign its the crank angle sensor?
ive spend days nobbing about, she`s such a good girl normally.
deathsminion
Chrgd,Coold,Twinthrot'in
GT42R forced JZA80 Supra and VT Wagon
It does sound like the CAS. I think running water over it can help.
H
HATER VP
Guest
Does it have spark at the plugs? Fuel flow and pressure? Compression
metalskin
get sum
47
perth
cheers, i been looking for it! it has power to the coil, i admit she does seem to be spinning over quicker than normal. i shall short the ecu and see if any codes come up. i sprayed aero-start down throttle body to see if she`d fire to tell me if its fuel and no sign of life. cheers.
greenfoam
99
VP Executive R-spec
The ignition module is the most likely thing to break with the 5 liter
metalskin
get sum
47
perth
i did a diagnostic check and got code 12, that means no problem i think. still wont fire. bugger.
Famine
33
VR Berlina V6
did you wait for the code to be repeated 3 times? I made that mistake, code 12 repeated 3 times then I just turned the ignition off. Every code is repeated 3 times so wait till after code 12 comes up 3 times, then check for a different error code.
joesvs
97 VS Wagon
does it crank over??? u know, does it turn but not want to start? what's it sound like? do you have full dash lights?
noah_73
VY SS Wagon
Igniter will be your problem most likely if you have no spark. Silver thing on the left hand guard from memory.
