Stability Control Alert problem
stevenroar
2006 VE Omega / Look-a-like SSV
Hey guys,
Just wondering if any of you would know why in my 06 v6 omega ill be driving along and the stability control will turn its self off then back on in a split second?
Anyone else have this happen?
stevenroar
do you know why? is it something to worry about?
flyjoe180
New Zealand
VE SV6
My SV6 does it occasionally, no problem according to Mr Holden at last service.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
For 06 and 07 models up to build date 14/9/07:
The Engine ECU fails to send a message that is required by the EBCM. As a result the EBCM logs a DTC and the warning is displayed on the instrument cluster. The message is only missing momentarily; as soon as the message is received correctly, the warning
disappears. This error can occur and then correct itself so fast that the driver may not see the warning message, they may just hear the warning chime.
Its fixed by reprogramming the IPC.
greenacc
Searching for the billion
VE Berlina
Happens sometimes when driving on bumpy roads. Hopefully it just needs a computer flash as Ricey said.
Shamous69
Toowoomba, QLD
VE SSV MY09
My 07 omega does it too.. it could be months inbetween instances or it could do it twice in a day.. looks like it's a common thing
stevenroar
yeah cool, awesome thanks guys heaps of help, and no need to stress now hah!
