vinnycolouda
Hey VE/VF Holden electrical gurus out there.
Have a 2011 VEII SV6 that’s just spat up a “contact dealer and Stability Control Fault message on the dash. Unable to crank. Both these messages alternate. Sticking my ULM scanner on there showed code U0100 (ECU no communication). Tried resetting, no good initially, then after a time, hear a clunk somewhere, wasn’t really taking note, then messages went from dash. Was able to crank and start but had engine light and additional codes now showing “P0700 Transmission control system MIL request, “P069E, Fuel Pump control module MIL request, and also an ABS code that I don’t recall.
Following this I could reset all DTCs and all good. Rescan and no DTCs. Drive car, all good.
10 mins later after shut down, go to start and same thing again with the alternating “contact dealer and Stability Control Fault message”. Unable to crank.
Battery voltage measured under bonnet not dropping below 12.2v with ignition on with defect present, no cranking.
Any clues anyone? Are there any defects common to the VE commodore that would cause this issue? Will a TECH 2 scan drill deep enough to give a clue on what might be causing this? Possible CAN Bus wiring issue causing the communication DTC?
Any constructive advice would be appreciated….
Cheers Vin…
Cheers Vin…
