Hi I have a ve sv6 commodore and last week I was driving and it came up on the screen stability control off and I couldn't put it back on, then the next day it started saying contact dealer with a big x on the screen then it would come up check engine so I took it to the guy I got the service and he couldn't figure it out so I took it to Holden got a diagnostic test and it stated that it was the transmission and it felt like it when I drove it like it was having troubles going into gear but now it's only coming up with with stability turned off it's not having troubles going into gear it's not coming up with contact dealer and check engine anymore does anyone know what's going??? on please help cheers
check other post here with "check engine" this seems to be a common occurence now. is your VE about 130,000KM+ now? it could be several things as suggested by other forum users that causes this - I have the same issue... ABS ,MAF or Wheel Speed sensors? Throttle body? Battery? Loom fault? Timing Chain? Mechanics scanned my error faults and it came back with Wheel Speed Sensor fault, Altinator charge fault & Air Flow error. I havent been able to pin point my problem yet but I will probably start with replacing battery, check looms and clean sensors... Anyway hope this helps or gives you some direction forward...
I had a simular problem with the wiring loom that went over the dif to both real wheel speed sensors. The plug just in front of the off side rear wheel had a break in one of the wires. Maybe worth a check.
