My car will not start when I try to start it comes up contact dealer or stability control off and abs fault
Series I VE V6? If so, you’ll find that your throttle body is knackered Couple of hundred to replace and is quite easy to do yourself if you’re handy on the tools
give the throttle body air box and any attached hoses a good clean and see how you go. the oil builds up in there causing issues.done my missus one 6 months ago and no problems since.
