staling vr 5ltr calais
tailhappy vn
I H8 FORDS
sydney
vn 5ltr auto vr v6 5spd vt v6 wagon
gday guys and girls new 2 the forum have a 5ltr calais hsv enhanced and wen is at running temp and put in reverse or drive she stalls any suggestions would be appreciated cheers:bang:
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Descent Gilly
vr ute
i recently had this problem. i changed the coil and its all good.
i wouldnt put the coil in the original spot. move it to the inner guard and it'll be better.
i couldnt get the original coil out so i broke the wires off.the brown wire is the ground or negative and the red the positive
good luck
Chris E
Vr Executive 3.8
Just a thought, my Vr V6 was doing this really badly recently, I couldn't stop the car in drive at idle without it stalling let alone changing directions.
The alternator had packed it in and I had put a new alternator in and the car ran like an absolute pig, stalling/ misfiring, the gearbox dropped first gear and went into limp mode, checked it out and the new alternator was playing up, once I changed the alternator again she runs smooth as without any problems.
Most probably isn't this but thought i'd let you know just in case.
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
tailhappy vn
I H8 FORDS
sydney
cheers i will check coil an ignition switch i must ask is their a way to reply to all my msgs at once or must this be done one by one.
tailhappy vn
I H8 FORDS
sydney
cheers mate yes i would imagine it would get hot and suffocate were it is not a great spot..
tailhappy vn
I H8 FORDS
sydney
thats an idea cheers will check
tailhappy vn
I H8 FORDS
sydney
i have had that checked and all is good but cheers 4 your reply
