Standard 15” rims max tyre size
Silver92
47
Langwarrin Victoria
Vz commodore sedan
Hi have a stock standard vz commodore sedan wondering if 65x225x15 tyres would fit and its standard ride height.
Lacksballs
www.youtube.com
VK Group C Replica
Holden states in its hand book for VZ Commodore:
P205/65 R15 95H for 15inch wheels, P215/60 R16 95V for 16inch wheels; P225/50 R17 94V for 17inch wheels on Calais; P235/45 R17 93V for 17inch wheels on SV6, SV8; P235/40 R18 91W for 18inch on SS
So: your 225x65x15 tyre request is 20mm wider & 13mm taller (ride height) which is no problem as far as clearance is concerned, there will be a difference with "actual speed" reading with the speedo.
C-man
Sunshine coast Qld.
2006 SS Thunder Ute 6ltr V8 manual
[QUOTE=VZ Commodore:
If I have 18" wheels and want the oppisite of low profile, what is the most rubber size I can run on a VZ SS thunder ute? not lowered
can I run 285/55-18? for that "old school look and extra rubber to soften the ride?
Wozza
VR_GS commodore
No the profile will be to tall, most states only allow 15mm over or under standard tyre fitment...
use a tyre calculator to work out what profile will work..use the tyre size difference comparison section here
https://www.exploroz.com/vehicle/tyres/sizecalc.aspx
lowandslow
NSW
V2 III Monaro
Im running 225 60 15 on 7 inch wide ute steel wheels. This is the tyre combo that the police used.
