Standard ride height of a '94 VR Berlina
BerlinaBoy
Brisbane (Southside)
V6 VR Berlina - Stock standard
Can anyone tell me the standard (factory) front and rear ride height, e.g. hub to guard, of a VR Berlina - with IRS if it makes a difference.
Mine is sitting on the original springs and I'm wondering how much they have sagged and whether I should replace them when I replace the shocks/struts - they have all done well to get to 203 000 km.
Thanks in advance.
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
Thanks in advance.
Depends who's measuring, normally its from the road to the lowest point of the vehicle (anything, exhaust, bodykit). I think vr has standard clearance of 143mm
BerlinaBoy
That would be about right for the exhaust, but since the rubber mounts would have stretched and the exhaust is a replacement I'm not sure if it means much. Exhaust certainly looks like it should be higher, including the hole forming just behind the cat where the pipe has scraped a couple of times.
I make the sump as being about 175 mm off the ground and centre of wheel to guard lip distances (on level ground after a quick bounce) as being about:
Front driver's 370 mm
Front pass. 380 mm
Rear driver's 390 mm
Rear pass. 380 mm
So she's a level on the passenger's side, but a bit out of whack on the driver's side and overall. Anyone know if that's enough to make a difference? Sounds a bit suss to me.
Seems to be a few stats for lowered suspension around, so I might try to back-calculate from those.
BerlinaBoy
Update: Redbook here says the height is 1478 mm and a level on the roof to a tape says mine is 1450 mm, so yeah, she's dropped a bit (28 mm, just over an inch!) as expected.
Seems to make it somewhere equivalent to between FE2 and Low from what I make of it, which is worth noting if you're interested in lowering your car.
Anybody else have some measurements from theirs so I can confirm? Only takes a min. (BTW mine is a V6)
justbad4you
IF YOR NOT A HOLDEN
ive got fe2 on mine so no point in me measuring that...
