standard VZ Spring length
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by avery1995, Nov 2, 2012.
  1. avery1995
    avery1995 New Member
    Wyalkatchem WA
    07 VZ SVZ
    i have a stock VZ SVZ Ute and i am wondering what the standard length of the front and rear springs are??
  2. CONROD
    CONROD Member
    SOMEWHERE in the land of OZ
    VZ SS THUNDER 6.0l 6 Sp
    Hey mate the following measurements are for the original FE-2 springs out of my VZ SS Thunder;
    Front;---part #-92048200
    code on tag--HK
    length--345mm
    Rear;---part #-92048209
    code on tag--EL
    length--280mm
    These measurements were taken with the spring standing on its end and tape measure passed down thru the centre of the spring and its end resting on the concrete floor and a straight edge place across the top.
    Note;; These measurements are from new almost unused springs.Springs that have been in use for a period of time could differ from those given
    Hope that helps you out mate,
    Cheers CONROD
