Start fault vs
Luke.76
44
Proserpine
VS Olympic ute v6
Parked my ute in the shed as normal, went back to it hit the key and got dash lights and stereo but no start.checked the neutral safety switch and it checks out ok. Ran a bridging earth wire to the starter relay and it will wind over but won't fire. Where should I check next please? 2000 vs Olympic edition ute
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
When you say the neutral start switch checks out ok, did you try and start it in neutral?
Other than that, could be the ignition switch itself.
Luke.76
44
Proserpine
VS Olympic ute v6
Tested it as in checking continuity with multimeter in park and neutral.
When bridging the start relay earth pin to earth then turning the key the engine will turn over but not fire
BlackVXGTS
Melbourne, SE
It would be more appropriate to post your problem in the VR/VS Forum.
Luke.76
44
Proserpine
VS Olympic ute v6
Only new here we're have I posted this... Sorry to bother you
