starter motor on a cross8
yowiie
Glen Innes NSW 2370
VX Clubsport
Has anyone had to replace the starter on a cross8 or adventra
If so give me some tips, it doesn't look like a 5 minute job
Atom555
37
Lounge chair on wheels - VY ls1 caprice
It should take you 2 to 3 hours
You’ll need.
Remove the starter motor
13mm socket
Extension bar
Ratchet
13mm ring spanner - for red cable l
Remove exhaust
13mm socket
Uni joint
Extension bars
Ratchet
15mm socket
16 or 17mm for exhaust bolt near the centre bearing
Disconnect negative battery terminal
Remove exhaust by the 2 x 13mm bolts near the starter motor
Remove the 16 or 17mm nuts from exhaust partition at the centre bearing
Remove 15mm nut which holds the exhaust to the mounting braxket from the gearbox
Disconnect the oxygen sensor from the plug
With the 13mm socket and extension bar
Remove 2 x mounting bolts to the starter
Remove 13mm nut from starter motor - red cable
Remove the female spade connector
Manhandle the starter out.
Installation is the same steps but in reverse
Good luck
