Starter Motor wire
Stewart1000
work done by ME
vic
www.justcommodores.com.au
VL twin turbo. VN5L. old jeep, **** mondeo.
i am in need of a bit of advise, i want to put a kill switch on the wire to the starter motor. where can i find the wire that goes from the ignition to the starter motor, what colour is is? i have all the covers off around the steering collum so i can see it all, i want to get it done tomorrow as i have the day off work, also friday but yeah i would like to get it done tomorrow, thanks in advance,
Stewart
VQXTC
3rd planet from the Sun...
HSV VP Senator, VY SS Crewman
Stewart
Hey there not sure if you have done it or not......
But the wire is a thick purple coming from the ignition if you cut this wire then it will cut the starter motor........hope this helps cheers
G
Grantis1976
Guest
hell of alot easier, safer, and a bit better hidden if you go for the fuel pump instead.
your call at the end of the day
VQXTC
Ok well in that case it is a thick purple wire located in behind the drivers side kick panel........confused yet???? LOL
