Starter motor woes
Discussion in 'Electrical Wiring / Questions' started by bluevhsle, Sep 15, 2019.
  1. bluevhsle
    bluevhsle New Member
    vh sle
    hi all,
    Hopefully someone can give me a solution to my issue.
    Vh 308 auto, clicking starter, will not turn over.
    Replaced solenoid as a precaution.
    Same.
    Ran a wire from 12v side of solenoid to ignition terminal on solenoid, click. Won’t turn over.
    Ran wire from 12v side of solenoid to starter wire, the one from solenoid to the starter body, starter spins.
    What the hell is wrong?
    Thanks
  2. rambunctious
    rambunctious Well-Known Member
    Mooloolaba
    VZ Wagon
    First thing to try is tapping the starter with hammer etc
    Tap toward the front because that is where the brushes are
    This will jar the brushes into place in the housing as they often get jammed
    Tap tap not bash bash
    If this works remove starter and service
    Next thing
    Make sure car is in park (auto) or out of gear (manual)
    Turn ignition on.
    Use screw driver to bridge between starter switch pin and main terminal
    If starter spins, but does not throw in, bridge across other terminal
    If starter throws in and spins engine, then you have an old wiring problem, easiest fixed by installing a relay on the starter.
    otherwise, remove starter and service.
    Often only requires clean up and brushes
  3. Aussie Trev
    Aussie Trev Active Member
    Queensland
    2 by VX Acclaim Wagon Series II 2001 & 2002
    If I'm understanding what you are saying correctly it sounds like the solenoid is not pulling in far enough to complete the circuit even with the new one. Was it a new one by the way or a secondhand one?. Could be caused by a bad earth or if the replacement solenoid was not new then worn contacts within the solenoid. Alternatively as ramB said, the voltage to the solenoid terminal is dropping due to high resistance somewhere along the line and can be easily fixed by inserting a relay close to the starter.
  4. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    As a first step it’s always good idea to check the battery voltage. It’s easy to over look this simple check if the battery still has the juice to light up the dash but not enough to get the starter turning the engine, since if the battery is low, the starter may not work and you get a click click click sound.
  5. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    The throw gear isn't working
  6. Trevor loves holden.
    vs commodore
  7. the_boozer
    the_boozer no more VK
    morwell
    Prado
    if you mean you put 12 volts onto the bottom terminal and the starter freewheeled that's normal, if the battery wasn't flat I guess you have the starter out by now. easier to test at the starter relay?
  8. Trevor loves holden.
    vs commodore
    Your ignition has to be on too if you want it to start.
  9. Trevor loves holden.
    vs commodore
  10. bluevhsle
    vh sle
    Thanks everyone.
    Very helpful.
