should be a round crimp on terminal that goes on the positive battery pole of the starter with the main fat power wire if you dont have one dangling round not connected it can sometimes be feed from the battery positive instead of the starter.sometimes it is attached to the starter with a spade terminal like the crank wire as well.this will supply the ignition switch or fuse box with power
