starter ???????????
lukieboy
newcastle
vp executive 92
hey guys and gals got a quick question for yas will a vp starter fit on a vr???
the gf brought a vr and the ****er wont start i have tried charging the battery no good tried useing mine (from a vp less than three month old) the vr has power just wont kick over so i was gunna swap starter and see if that helps
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Hit the solenoid with a hammer or something heavy and see if it starts then. As far as I know they are the same. The VN series 1 was different, then the VS changed again.
lukieboy
newcastle
vp executive 92
ok i jumped it ran it for like an hour turned her of then nothing but ticking after a piss weak attempt at starting
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Sounds like the battery then.
lukieboy
newcastle
vp executive 92
aint the battery i put a brand spankin new one in same problem grrrrrrrrrrrrrrr
pow3rslave
DoNothing Member
eastern subs, vic
VP 5.0L
could be the alternator not charging the battery. or did you mean you put a new battery in and the problem happened right away, before any charging.
is it auto or manual btw?
lukieboy
newcastle
vp executive 92
yeah new battery and no start straight away and sh is auto
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Have you checked the connections on the starter and the battery, make sure they are tight.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
might be the inhibitor switch on the gear lever try in neutral instead of park
